Gast Rogier Jansen Geplaatst: 29 oktober 2010 Rapporteer Delen Geplaatst: 29 oktober 2010 http://www.venomgt.com/2011 Hennessey Venom GT SpecificationsPerformance0 – 60 mph 2.5 sec. 1/4 Mile 9.9 sec. @ 162 mph 0 – 200 mph 15.9 sec. (Bugatti Veyron = 24.2 sec.) Top Speed 267 mph PowerHorsepower 1,200 bhp @ 6,500 rpm Torque 1,155 lb-ft @ 4,200 rpm Specific Output 166 bhp / Liter Bhp / Weight 767.23 hp per ton or 2.61 lbs / hp Boost 16 psi (1.1 bar) Fuel 93 octane --------------------------------------------------------------------------------EngineType V8 Block Aluminum Size 376 CID (6.2 Liter) Position Mid Longitudinal Compression 8.8:1 Redline 7,200 rpm Forced Induction Twin Garrett Ball Bearing Turbochargers Oiling System Dry Sump Lubrication Fuel System Sequential Multi-Port Electronic Fuel Injection TransmissionType Ricardo 6-Speed Manual Gear Ratios 2.61:1, 1.71:1, 1.23:1, 0.94:1, 0.77:1, 0.63:1 Final Drive 3.36:1 BrakesCalipers Brembo 6-Piston (all four corners) Rotors 15.0 x 1.34 in. Carbon Ceramic (all four corners) SuspensionType KW Variant 3 Adjustable Coilover (all four corners) Ride Height Adjustable by 2.4 inches (60 mm) DimensionsLength 15.27 ft. (4,655 mm) Width 6.43 ft. (1,960 mm) Wheelbase 110.24 in. (2,800 mm) Track – Front 63.46 in. (1,612 mm) Track – Rear 63.15 in. (1,604 mm) BodyMaterial Carbon fiber composite except doors & roof Type 2-door Weights & MeasuresCurb Weight 2,685 lbs (1,220 kilo) Dry Weight 2,524 lbs (1,147 kilo) F / R Balance 37 / 63 (empty); 44 / 56 (with driver & passenger) Fuel Capacity 18.5 gal. (70 Liter) Wheels & TiresTire – Front 235/30/20 Michelin PS2 Tire – Rear 335/30/20 Michelin PS2 Wheel – Front 8.5 x 20 in. Wheel – Rear 12.5 x 20 in. Link naar reactie Delen op andere sites Meer opties om te delen...
J. Tarry Geplaatst: 29 oktober 2010 Rapporteer Delen Geplaatst: 29 oktober 2010 Price? Wat een ongelovelijk gaaf ding...beetje een geplet Exige look...niiiiiice.Want one. Link naar reactie Delen op andere sites Meer opties om te delen...
Harm Boerma Geplaatst: 29 oktober 2010 Rapporteer Delen Geplaatst: 29 oktober 2010 yeah want one tois de grote broer van de exige in grote lijnenmaaaarrrr dan veel spannender Link naar reactie Delen op andere sites Meer opties om te delen...
Gast Johannes Timmermans Geplaatst: 29 oktober 2010 Rapporteer Delen Geplaatst: 29 oktober 2010 Zou dit wel aan de Nederlandse geluidseisen voldoen ???Schitterende kar !Groet,Johannes Link naar reactie Delen op andere sites Meer opties om te delen...
